Does replacing the charging port require soldering?
Does replacing the charging port require soldering? If it does, where can I get soldering tools?
Yes. You will probably need a micro-soldering iron. Check with an electronics store. You probably need a good amount of experience in soldering as well.
You should probably purchase a new motherboard since it is soldered on. It's pretty simple to replace
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 232
