Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20029 Questions View all
Question Closed
Repartitioning fails in Internet recovery: is the HD salvageable?
Internal HD failure in Early 2011 unibody. Had recent-enough backups (of individual important files, not Time-Machine-formatted), so decided to just reinstall from Internet Recovery. The HD showed in Disk Utility, but showed as a single unformatted partition. Okay, reformat the drive. This gave the "Unable to write to last block" error
On a few subsequent tries, it seems that the internal hard drive will show (unformatted) if I enter Disk Utility immediately, but will not show if I quit and re-enter Disk Utility (without a backup), nor will it show in the Reinstall utility. DU shows no problems recognizing the external HD or optical drive, so it's unique to that drive.
So: is the drive totally borked? I can try to set up the external to boot from, but I imagine it would throw a similar error. I opened up the case and checked that the HD cable and bracket weren't loose or dusty, but I didn't look for anything more specific than that.
Add a comment
1 Answer
Chosen Solution
Put the drive in an external enclosure or use a Universal adapter. This will bypass the suspect hard drive/IR cable that are notorious for failure.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 148
