Wiggling home button?
I was fixing a cracked iphone 5c and when i put the home button back in it can rotate to the sides even when i took glue put it around the spot it didn't work? I need to make it stop wiggling.
Replace the rubber adhesive ring, it's not that precious.
As you no it's the glues problem on the rubber gasket around the home button if you take it out and heat the rubber with a hair dryer it should activate the stickiness of the adesive again
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 78
