The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Questions View all
Sony PS3: Cannot connect to Internet via wireless or wired connection
Right after the latest firmware upgrade from Sony (4.55?) my CECHK01 cannot connect to the internet. I have reset the device back to the factory setting several times, used different ethernet cables, connected directly to the FiOS router. It gives me error codes such as 8001000B and 8001000A. Any ideas how to repair? Is it a hardware issue?
Score 2
1 Comment:
i had this issue too. i ended up using my laptop connected the ethernet cord to both. ran test and finally it worked
by
Add a comment
Go over the instructions at this link carefully http://manuals.playstation.net/document/...
If the connection still fails after following these instructions, follow the on-screen instructions to check your settings.
If it still does not work then your router might be blocking your ps3 from connecting
1. Locate the PS3 MAC address number: Settings - System Settings - System Information
2. Follow your routers steps to add a MAC Address to the whitelist/Disable the MAC Address whitelist
Add a comment
I had this problem too.,but when I did a factory reset,I tried it again.If your not still satisfied you can send me a mail and I will be glad to reply to you .If any mail is sent to me and it will be replied as soon as possible .
2 Comments:
Mine will connect to my network for 30 seconds, then sees no wireless or wired connections. I start an update and it just disconnects and does nothing but pops up with these same error codes. Factory reset didn't do anything to fix it.
by
Mine too. Any luck fixing it
by
Add a comment
Add your answer
Tom DePrenda will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 69
All Time: 29,719
