Using HDMI Monitor instead original LED Screen
I Have broken display i'm about to remove it and just using External HDMI Monitor via thunderbolt,
If that so will it work ?
and i'm about to buy Logic Board only and connect it using external HDMI Monitor
and if no OS X yet can i install it without internal display ?
3 Comments
@Dan, so i just using a Thunderbolt and no internal display , that will be ok ?
by haidar
Yes, you will be using the external HDMI display (not your broken internal)
by Dan
Also did you check to see if the display is covered under warranty? Visit an Apple Store or authorized support center. As long as you haven't physically damaged your system they should fix it for free.
by Dan
