Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
None functional screen after replacement!
Hello,
I tried to replace a screen on an iPhone 5 this day and stumbled on an issue I've never seen before.
I've replaced hundreds of screens and never had this problem before. Is there any easy fix for this or is the screen just malfunctional?
See the pictures below:
http://sv.tinypic.com/r/10rkbp2/8
http://sv.tinypic.com/r/r240go/8
Thanks in advance guys!
Add a comment
Front camera flex is damaged disconnect the front camera connecter and restart phone this should disappear if it does then you need to replace the camera flex
1 Comment:
You're unable to restart the phone once the text appeared. I have to disconnect the battery to shut it off!
Do you think it will work if I disconnect the flex cable and restart the phone?
by
Add a comment
Yes disconnect the battery then disconnect the camera flex and start phone again see what the out come is
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 59
