broken home button clip connector in iPhone frame
i broke the connector on the iPhone metal frame that clips to the home button cable inside the iPhone metal housing, can i fix it or get a replace frame for the iPhone 4?
You can get replacement frames on eBay there not very expensive post a pic of the bit that's broke as I'm unsure what your talking about
The home button flex connector is a component of the "charging port assembly with flex cable", which also contains the lower mic. This is the replacement part you need.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 201
