Model A1106 / 1280x854 screen resolution
90 Questions View all
When Plug In and with the battery, still doesn't work
When Plug In and with the battery, still doesn't work. Turns on but black screen and nothing on it. ...without the battery and plug in works fine. I ordered a new battery and still When Plug In doesn't work. Any idea what I can do to fix it? Any help is greatly appreciate it
Thanks
Marcela
Update
Update
Score -1
2 Comments
Does it work with the battery only? Ralph
by
no, it does not.
by
Add a comment
1 Answer
Most Helpful Answer
First download and run Coconut battery just to see where it's at: http://www.coconut-flavour.com/coconutba...
Next reset the SMU:
Unplug the computer's power cord.
Press and hold the power button for 5 seconds.
Release the power button.
Attach the computers power cable.
Press the power button to turn on the computer.
Let us know the results and we'll go from there.
Score 1
9 Comments:
I did what you suggested. Then Release the power button.Attach the computers power cable.All with the battery attached and the computer turned on with no problem. Then I tried to turned it on only with the battery on and the screen went black and nothing on it, the battery is 100% charged. Any more advice?
by
I did the test with coconutbattery and all is ok and it is charge100% but still the computer doesn't work with the battery only.
What else could I do to solve this problem? Thanks so much for all your help and advice.
by
Zap the PRAM next, here's how and look at the answer from rdkl: iBook won't power on after attempted PMU reset
by
If you jump around I won't be able to find you. If you zapped the PRAM then try starting in "Safe Mode" by holding down the "shift key" when starting up. Remember I'm working blind here and trusting that you are doing as instructed. Sometimes we have to try a lot of things and there are work arounds to many problems. Hang in there, you are in good hands and there are a lot of experts here to help you. If I tell you something wrong, be very assured someone will chime in quickly to correct me, but I've done this for over 30 years and seldom give up on a problem. Don't panic.
by
Hi, thanks for your help I just tried starting in "Safe Mode" by holding down the "shift key" when starting up but did not help. I continue seeing the apple display only on a persistent gray screen with a spinning gear below. Thanks again for the help I am thankful for your wiliness to share your knowledge and 30 years of experience rarely giving up on a problem.
by
Show 4 more comments
Add a comment
Add your answer
marcela will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,423
