Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
iPhone compass/GPS not working...
Hi,
My iPhone3GS GPS/compass doesn't work. In the maps application the locate button doesn't secure a lock. The compass application shows 0 deg at all times.
Have tried restoring to 3.1.2 but doesn't help. Looks like a h/w problem. Any pointers?
TIA.
Score 1
1 Comment
Fixed it! Try this link and follow the instructions on Terminal closely if you face this issue.
http://forums.macrumors.com/showthread.p...
by
Add a comment
1 Answer
Most Helpful Answer
Has the phone ever been taken apart before? You may want to make sure that ribbons 6 & 7 are properly seated in their spaces.
Score 1
1 Comment:
Nope, its never been taken apart. It used to work perfectly fine. I got the 3GS in July of 2009. The GPS and the compass were always accurate. Just wondering, if the compass doesn't work will that make the GPS fail too? What are the chances that both the chips (the chip for the compass and the GPS chip) have failed at the same time?
by
Add a comment
Add your answer
Fatal Milk will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 9,546
