The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Questions View all
Question Closed
Can inoperative Menu, Back buttons and lights be fixed?
(SGH1337) I have two S4s. On #1, the LCD needed replacing. #2 was water damaged but LCD ok only the camera failed. I swapped the LCDs following your excellent guide. #1 swapped LCD and all functions now work great except the L and R Menu and Back lights and functions on the bottom of the screen have disappeared. Any ideas? I did recheck all connections.
Add a comment
1 Answer
Seems the water damage has damaged the lights I would clean the connector with ISO alcohol and let dry then connect again and see if it works.. If not then there's not a lot you can do
Add a comment
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 1,997
