A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 Questions View all
Question Closed
when turned on it goes to a black screen
when turned on my Toshiba Satellite c855d-s5357 goes to a black screen and says no bootable service- please restart system. I have tried to take battery out and restart but it just goes to the same screen.
Add a comment
1 Answer
Most Helpful Answer
Hi,
Go in the BIOS (F2). Check in the "Main" menu do you have HDD/SSD. (If no - you have a problem with the HDD) If yes, go to "Exit" and do "Load Setup Default" and restart the laptop. If you have the same problem, boot you laptop with a bootable CD or USB pen. It's good to check HDD for BAD sectors. If all is OK, boot you laptop with a Windows Recovery CD and try to recover your Windows. Finally, if this not working, install new Windows.
Regards.
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 157
