Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
Stuck in a Safe mode crash loop with a Cracked Screen
My Mac fell over yesterday and landed on my DS. It now has a crack in the lower middle of the screen, causing some lines to run across the screen. It still works fine other than the fact that it has some kindof fatal problem with safe mode, that i have no idea how to fix.
Can someone help me? I would much rather get past the safe mode first before handing out money to fix a computer that wont work. I also have some work and software on that machine i don't know if i can replace. But am i going to have to just face the truth and give it up? I really hope that there is another way.
Score -1
Add a comment
1 Answer
Chosen Solution
You may have had some hard drive problems with the fall or possibly loose connections. If you can boot your system disk go to utilities/disk repair and run disk repair until it reports no trouble found. If that doe not help you need to open it up and see if anything has come loose. Ralph
iMac Intel 20" EMC 2105 and 2118
Score 1
Add a comment
Add your answer
Mike Adams will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,526
