Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Question Closed
Can I get data from my unrepairable iPod 4th gen?
I have an iPod Touch 4th gen 32 GB which was working fine then stopped charging. I ordered a battery from iFixit and carefully did the repair - pulling in an expert friend for the soldering - but no luck - still dead. I suspect it could be the charging port or a mistake on the soldering. Can I get any data (photos) from this device by removing a card/chip and using a card reader or is this data not able to be recovered?
Score 1
1 Comment
This question was migrated from http://meta.ifixit.com/Answers.
by
Add a comment
1 Answer
Most Helpful Answer
The iPod Touch 4G uses Toshiba NAND flash drive memory for data storage, and accessing this (by taking it out and putting it into a working iPod Touch, for example) is almost impossibly difficult.
For more info you can check out the teardown, or perhaps this answer: Toshiba NAND Flash Memory - one or two chips?
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 804
