The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
602 Questions View all
I replaced my S4 LCD Screen, how do I get the sound working again?
I cracked my Lcd and had to order a new one. installed it, now I have no sound. Is there any way of fixing it?
Score 2
Comments:
I have the same problem, did you figure out any solution?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Solutions for loudspeaker for Galaxy S4 I9505 no sound problem(from http://www.witrigs.com/replacement-parts...)
When external speaker for Galaxy S4 I9505 is broken, your phone doesn’t ring, sound notified or plays music/videos out. But if you plug the headphones in, everything comes back again. Bringing such a huge annoyance, it is speaker for Galaxy S4 not working that becomes a must solve problem.
Step 1. Check the setting
Go into the settings > sound > volume, make sure you didn’t turn on the vibration or silent switch, adjust the volume for music, ringtones and notifications, and then to hear if the Galaxy S4 no sound still.
Step 2. Reboot the phone
Hold on the power button and choose the restart option, hopefully do like this will eliminate any glitches causing the problem.
Step 3. Update software
For those who have not update OS, it will be a nice try. For others, you can find other ways to solve the problem of Galaxy S4 no sound.
Step 4. Replace loudspeaker
If all above the steps are failed, what you should consider is hardware problem and to replace a new speaker enclosure. If the trouble that speaker for Galaxy S4 not working still exists, send it to the repair center for checking the logic board.
Also, you should make sure if your USB board is installed well, because the loudspeaker is connected with it by two spring chips.
Add a comment
I also had a similar issue. After completing the screen repair the in-call audio is diverted to bluetooth even when the bluetooth is turned off. Connecting to a bluetooth device is the only way to hear anything, incoming or outgoing. I'm more than certain it's not a hardware issue. Might either of you have an idea that may help?
Comments:
by
Add a comment
I have a samsung s4 and i cant hear the sound or music it has interior screen damage what can i do to make it work
Add a comment
Add your answer
Vince will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 82
All Time: 4,484
