Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
iPhone 5 earspeaker problems
Today I check a iphone 5, the problem is earspeaker no sound. Then I change a new earspeaker put on. Strange things is when I haven't push the screen panel in, the earspeaker sounds good. But after push the screen panel in, the earspeaker doesn't work again. Then I open the screen panel again to check, I haven't find an problem. What's the problem is.thanks a lots.
When I open the screen panel again, I can find three single connectors May when the screen close it will connect to the earspeaker cover, I think the problem maybe come from there, but not sure what's the problem.
Score -1
Add a comment
1 Answer
It seems that your earspeaker is good.
You have not installed it in right position.
Or you have not screw it well and it get loose.
Add a comment
Add your answer
Lemon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 121
