Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
No cellular service on my iPhone
After the screen repair my iPhone's could not find my cellular network. I have tried to do everything to fix it but nothing worked. So I decided that i am going to replace the cellular antenna, does any one know how to or have a link to a nice guide?
i found the component i need
iPhone 5 Cellular Antenna
any ideas?
iPhone 5 Cellular Antenna Image
Product
$9.99
Score -1
Add a comment
1 Answer
Did u take the battery out? Only reason I ask is there could be pry damage If you did.
The antenna you are looking for is attached to the dock and Is the little black thin wire that clips into the bottom of the logic board make sure it's still plugged in..
If it was only a screen replacement then you should not have damaged this part
Also make sure the two long black cables that run up the middle of the logic board are clipped in
5 Comments:
I didn't take the battery out, all i did was disconnect it.
i made sure and every things seems to be plugged in good ;/
by
There are little componants all around were the battery connector is my guess is you have knocked one off
by
so you think its the motherboard then?
by
It could be I would open up and inspect for damage around the battery connector
by
I inspected it very carefully, I see nothing that's not normal.
by
Add a comment
Add your answer
Jon will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 731
