Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Battery tab ripped off, how can I remove still?
So I got the phone opened up to the last step to remove the battery. I tried pulling on the tab to remove the battery and it ripped right off. So, my question is I tried to pry along the edges and quite frankly, I'm nervous to do it around the logic board and other areas, so how much pressure do I need to remove it? Can the battery be removed without the tab? Thanks!
Score 2
Add a comment
1 Answer
Most Helpful Answer
Hi there if you get a hair dryer and heat the rear of the case right aroun where the battery is this will loosen up the adesive..
What ever you do don't pry on the logic board side this is a no no..
Ok then the back is hot pry on the volume key side just below the ribbon cable so u don't rip it. It should pop up don't put to much pressure on it as the battery will bend.
Score 3
2 Comments:
That did the trick! Thanks!
by
Glad this worked got you I think the picture guide would need changed as prying around the mother board is dangers and not alot of people no this and think it's ok cause the guide says so
by
Add a comment
Add your answer
spencerlew2 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,775
