The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
209 Questions View all
light leaking onto screen from capactive buttons
after screen/digitizer replacement on note II, there is light leak (shinng light onto) from the capacitive button onto actual screen. not the normal reports of light bleed on the capacitive buttons but onto the screen. its only coming from the right capacitive button. left is fine. If I press hard down on the screen in that area it goes away, for a bit maybe an hr, then it comes back again.
Score -1
Add a comment
1 Answer
This situation may be caused by you didn't plug the connector very well, you can have a check and have a try to re-plug.
Add a comment
Add your answer
cbedlin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 230
