Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
no service or sound?
It shortly dropped in the water, I got it out quickly and stuck it in rice for a few days. After I took it out and cleaned it up inside with alcohol, yet I get no carrier signal and no sound. So I changed the ariel antenna and cleaned up some more, but no change, any ideas what it could be? And phone turns off but turns on by itself right away?
Score -1
Add a comment
Most Helpful Answer
You would have been better cleaning with alcohol first than dry it first as water causes corrosion on the motherboard.
There's a few things you will have to buy first off no service either means you have time and date incorrect.
Or you need a new antenna cable.
The no sound issue is either a faulty loud speaker or faulty dock as the loud speaker gets it's power from the dock
Score 1
Add a comment
Sometimes the phone works and other times no, usually after a reset on the network it will work for awhile, sometimes 10 min and other times an hour or 2 and then comes the no service. I had already changed the lower antenna where the speakers are, and exactly what did you think should be done with the date and time? I asked around and one suggested it could be a weak battery, what do u think about that? Thanks a lot, appreciate the help.
Add a comment
Add your answer
Horst will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 92
