Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Question Closed
Metal piece missing inside my iPhone, need help!
I tried to open my iPhone 5s and when I tried to 'pry'(?), the cable from the Touch ID got loosened and a little metal piece with 2 holes came off but I couldn't see from where.
I wanted to make sure that there wasn't water inside because the music wasn't clear after I made some calls after I came out of the shower, but since this metal piece came off the sound is normal again.
I closed my iPhone up again but I'm very worried, maybe someone could tell me where it belongs?
And also how to open the phone more carefully next time ? I tried as careful as possible but it just snapped (?)... :(
Thanks in advance
Add a comment
1 Answer
Chosen Solution
That little metal peice goes over the touch id connector
4 Comments:
Thanks^^ so that means it goes over the connector and is covered by the cable, right?
by
Also is that metal piece absolutely necessary? Because I'm a little bit cautious now about opening my iPhone and I'm a little afraid that the next time the cable could be damaged.
by
The metal peice is just placed over the button to stop it disconnecting if it had a bad drop so it doesn't matter if you leave it out won't affect the function of the iphone
by
That's a relief.
THANKS !!! :)
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 422
