Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Question Closed
Leftover part after Volume button cleaned
I changed the battery and cleaned the Volume button on my iPhone 4S, everything seemed to go alright but a part fell out while I was tilting the phone to lift out one of the phillips head screws I had removed. I went through a lot of tear down pictures and looked for other posts that might have that part left over. It is a short piece of metal braided tubing that appears to have foam in the center. About 2mm long and about the same width when flattened.
I have it next to the pentalobe dock connector screw for scale. I thought the cell signal was gone at first because the phone showed "searching..." in the bar indicator, I switched in and out of Airplane mode and it seems to be fine now.
1 Comment
Thank you! Glad to hear it is not critical but I will put it back.
by
Add a comment
1 Answer
Chosen Solution
Hi there this is a little cushion it sits in between the dock flex and the frame.
It is not needed but if your a perfectionist like me you'll put it back lol
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 86
