2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
Question Closed
Juice under screen In MacBook Pro Retina Mid 2012. What to do?
Story: I had laptop in my bag, and some M&S cranberry juice over it. Juice didn't go over laptop, but on the side of the bag. Laptop was clean, BUT I opened it and found out that there is a liquid behind the screen inside the shell. About 1/3 of the screen covered with this liquid which is upsetting.
How could I possibly clean it, if I can easily tear apart the laptop with closed eyes (except display)?
Add a comment
Chosen Solution
Opening up the display assembly without wrecking it is simply impossible, just get a new assembly.
Add a comment
mmm... Not sure your out of the woods here.
While you state the juice didn't get inside it must of have as the only gap for the display and the system is on the same side (hinge).
So I suspect you See the juice in the display, but some also went into the system wetting logic board.
At this point I would focus on making sure the logic board & battery are clean (as that is the heart of your system). Are you up to taking your system apart? Do you have the correct tools and ESD mat to work on it?
  • If not I would try locating an authorized Apple service center Vs an Apple store as they are a little bit more forgiving on wet systems.
  • In the mean time put your system in a plastic bag pulling out as much air out as possible and put your system in the refrigerator (cooled not ice cold!). This will slow down the corrosive action of the acids in the juice. If you can I would disconnect the battery as well.
OK, you have the tools then you'll need to take things apart fully. Follow this guide: MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement then using distilled water (not tap water). Wipe down the areas of the logic board that look like they got hit using cotton swabs (Q-Tips). You will likely need to go over the areas a few times to fully clean up all of the juices sugars & acids. Once you do an area go over it again this time with a high grade of Isopropyl alcohol (85% or better). Let the logic board fully dry and also check the rest of the systems internals for spillage.
As for the display you can follow this IFIXIT guide MacBook Pro Retina Display Teardown. I must warn you I've tried fixing one of these displays and I ended up getting a new lid assembly as I broke the glass. Trust me I was being very careful and still messed up! So be VERY careful! Or consider just replacing the lid assembly as it's just safer & quicker. Good Luck!
MacBook Pro 15" Retina Display Mid 2012 Image
Guide
Difficulty:
Moderate
MacBook Pro 15" Retina Display Mid 2012 Logic Board Image
Guide
Difficulty:
Difficult
1 - 4 hours
1 Comment:
Thanks a lot for suggestion. That helps. I will clean it up as you said, I have all needed tools. What about screen: what IF I take it off and put into bowl full of rice?
Thanks a lot,
Artur
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 538
