Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Question Closed
Dark display after replacement, possible broken logic board?
Hello.
I replaced the display assembly yesterday. After some trouble with white streaks, I tried to clean the contacts with both oxide cleaner and bandaid-cleaner.
Now the screen is dark, and the phone vibrates in sequence when connecting the power supply.
I tried to connect the old display again, but still the same.
I have also tried to recover through Itunes without luck.
Could the logic board be damaged while cleaning?
Does anyone know if it's possible to get a replacement logic board?
Add a comment
1 Answer
Chosen Solution
It's possible you have damaged pins on the board when cleaning any good repair shop that solders should be able to diagnose the problem.
And no you can not just buy a logic board
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 126
