2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
940 Questions View all
Can bad battery cause power issues?
I have a MacBook Pro 15" Core 2 Duo Model A1260 2.4. Can a failing battery cause the backlight for the keyboard to not work on a A1260 macbook pro? The caps lock light works but the keyboard no longer lights up and I am getting a service battery warning. I also have been noticing issues with performance even though I have the 85w adapter plugged in at all times. The logic board was replaced less then a year ago, and the battery a little over a year ago, bought it used, so I am replacing it. I just want to know if the culprit could be something else and if so, what could it be?
Add a comment
1 Answer
Chosen Solution
I think you are making the correct diagnosis. The backlight draws a lot of power, if the battery is wonky there may not be enough, or, the energy saver might be trying to keep your machine from crashing.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Add your answer
Nickole Schmidt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 99
