Display dark after HD swap. LEDs #3&4 off. Checking cables/connectors?
My 24" 2007-8 iMac and display worked fine until I did a hard drive replacement, following an excellent iFixit guide judiciously. The new hard drive works find, but the display never fired back up. I've gone in and done a few diagnostics (below), but before I put the iMac out to MacPasture, I want to go in one last time and check all the cables and connections for continuity with my meter, in case it's something from the work I did. BUT...
1. Just for grins, let's first assume that it's not a fried logic or graphics board, but is a cable that was broken, or a connector, or a cable was put in backwards, etc. Based on the following symptoms, which cable/connector thing(s) should I be looking at as a culprit?
- I've gone in once and made sure all the connections are solid.
- I can see the hard drive via target disk mode.
- An external monitor does not work.
- LED diagnostic lights #1 and #2 are on, but #3 and #4 are off.
- I was careful on static discharge always.
2. This isn't where I wanted to go, but how do I check to see if it's a bad logic board, graphics board, or something else?
Thank you very much in advance for any help.
