Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
175 Questions View all
Why is the screen white after repaiedr on/off button
Took mIne apart to fix the on/off button everything was worked perfect before but that. put it back together w/ extreme caution but the screen turns all white w/ noting on it now.
It does connect to I Tunes deletes and add song, plays from it but when I disconnect white screen only and it also does it when I plug the earphone jack aging white screen only
Score -1
Add a comment
Try shorting out the battery to the case, if you are still having problems then you will need to replace the LCD.
Add a comment
Hi Idive4fsh,
Did the propose solution work?
Thank you,
../Bruno
Add a comment
Add your answer
Idive4fsh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 272
