Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
LCD not working at all.
Hello,
Recently replaced an LCD, everything worked great. Decided to use phone to test remaining stock of LCD assemblies that came in as well. So I popped off the back, exposed the ribbon cables and proceeded to test each LCD one by one. At about the 5th one, I received absolutely nothing on the screen. No backlight, no LCD, zip. Thought it was a bad LCD. Then the next one. So I went back to ones that tested properly, nothing. Something has happened from one screen to the next. Any ideas? Thank you.
Score -1
1 Comment
update: Ive reconnected the internal display and it works. I don't understand because I haven't done anything differently. Is there any reason why this would happen?
I did not power down the device after every screen test.
by
Add a comment
1 Answer
Chosen Solution
Check your testing cable sounds like it is damaged.
Score 1
Add a comment
Add your answer
zentech will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 72
