Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
Replaced LCD. Screen is black. Able to answer calls and have sound.
I just replaced the LCD on my iphone 4. I cannot see the screen. I do hear sound when receiving messages or even answer calls. I was able to answer a call from my other phone sliding the finger where it should be done. I have rebooted the phone and still nothing. Even though I do not see anything, it kind of works because i was able to answer the call. What's wrong with my phone? Is the LCD messed up? is it some wiring?
Score -1
Add a comment
If you were already having this issue then the fix below will not work.
Check the flex cable and clean the contacts with 99% alcohol and a toothbrush (both the logic board and flex contacts). Make sure that the alcohol is at least 92% if you dont have 99%. No need to use much a little will do. Wait a couple of minutes till it dries a put it back together. It should be good. If the screen still is black then your screen needs to be returned.
3 Comments:
I have not clean anything inside the phone. Do you think that should make a difference?
by
You do have to start the process of elimination. cleaning the contacts is a common fix for a new screen fix.
by
I reconnected my broken screen and it still works and I can see everything on the screen. I put the other two digitizers I have received, and on both of them I cannot see anything. It seems that the digitizer is not working. I need to return the items back.
by
Add a comment
You can try to reboot.
1- by pressing homebutton and power power button together at least 20 seconds you should see apple logo
Or
2- remove battery and reconnect and press power button you should see appe logo
3- check any physical damage on or around lcd connector. If any resisor missing.
4- new lcd cable maybe bended and broken. Try with new lcd.
Good luck ....
Add a comment
Add your answer
Luis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 116
