Furby was a popular electronic robotic toy resembling a hamster/owl-like creature which went through a period of being a "must-have" toy following its launch in the holiday season of 1998, with continual sales until 2000. Furbies sold 1.8 million units in 1998, 14 million units in 1999, and altogether in its three years of original production, Furbies sold over 40 million units.
85 Questions View all
How can I fix for my furby does not speak?
My Furby doesn't not speak and only does the movement.
I thought that it is because of low battery.
Then I changed with new batteries.
But it still doesn't speak.
Score 15
7 Comments
Having same problem! What can we do?
by
Well i kinda have a similar problem only my boom speaks... but also the speaker makes this crackeling noise too. I replaced the speaker but firby still crackeling...out of ideas, what should i do???
by
My fur by will talk but u wouldn't be able to hear the voice what so ever I've tried every thing but it won't work what shall I do
by
Is there a place that repairs Furby?
by
Today I ordered a new speaker for my sons furby boom. It should be 16Ohms, but my meter shows me 4MOhms :(... I hope, after changing the speaker all is well again...
by
Show 2 more comments
Add a comment
Chosen Solution
sara, I would get to the "tummy switch" and check the circuit from there. You do have a couple of choices here. Check the switch, then the speaker. Check the connector for both. You will need a multimeter to check those. Follow the schematic to work on your Furby's voice, and check on here for directions on how to skin the Furby. Hope this helps, good luck.
Score 4
4 Comments:
I tried that and it won't work still, what should I do?I also don't want to remove the furry booms skin
by
My old furby doesn't work it has no voice only makeing gear sounds he works fine but thats his only problem i took him apart but dont know how to fix the problem
by
Hi.
Did you manage to find a fix?
Dame problem here
by
To repair this you may have to replace the speaker. 2 ways to get one is find a speaker online or buy a parts furby to take the speaker from. One one thing I'd advise against the parts furbies is that most of them actually work but the gears are stuck and to fix them you got to bang the bottom of them super hard against your palm for awhile.
by
Add a comment
If you have installed fresh batteries, and Furby still won't talk, push the reset button and the tongue at the same time when the Furby is turned on.To turn on the Furby, turn it completely upside down and back upright again.
Score 2
1 Comment:
It weren't help full it carried on silent help what shall I do ?
by
Add a comment
I had the same problem but mine had some noise and it was a normal furby.I changed the batterys and held recet for 20 seconds
1 Comment:
Where's the reset button ?
by
Add a comment
I change the speaker with a new one. It works for me.
1 Comment:
Where did you get a new speaker,
by
Add a comment
Where can I purchase a Furby speaker?
1 Comment:
You'll need a donor furby, you can find some cheap ones online that are being sold for parts
by
Add a comment
I use this part:
https://www.amazon.de/gp/product/B00UJ99...
The original one is a litle bit louder!
1 Comment:
My.furby is talking but the volume is very low..I can barely hear it..what can I do
by
Add a comment
Add your answer
sara will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 36
Past 30 Days: 184
All Time: 33,128
