Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
Why is my iPhone turning on just sometimes?
Well my iphone got wet a week ago & it can works perfectly, but it needs to be conected to the power source & i just can turn it on sometimes, the Other times it shows the red dead battery even when the battery is at 68%
Add a comment
1 Answer
Chosen Solution
Yerudo. "as with an immersion, the importance is to not turn it on, or trying to sync/charge it, as this may increase the likelihood of shortcircuiting any components. Remove the battery, and disassemble it right down to the logic board. Clean everything with isopropyl alcohol (90%+) and a soft brush, including all connectors and cable ends. Check for any burned or missing components. You may have to repeat this step a couple of times. Once it is cleaned, reassemble it and replace the battery, then reevaluate for any real damage. Yes, it is possible that all of your problems originate from the battery, but you do want to avoid any failure later on. So, clean it very well. Hope this helps, good luck."
Score 2
Add a comment
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 87
