Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Question Closed
The up arrow key is hot.
The up arrow key continuously clicks. Is there a way to inhibit this key in the operating system? An easy way to clean the keyboard? I believe I spilled Ice cream on it years ago...
Add a comment
1 Answer
Chosen Solution
Have you tried popping off the key caps and giving the area a good clean? To start with make sure your system is fully off. Then get some distilled water (not tap!) with a cotton swab (Q-Tip) wipe down the area once your sure all of the water soluble stuff is off go over the areas again this time with a high grade isopropyl alcohol (85% or better).
Heres a good vid on popping the key caps off. YouTube Vid
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 89
