Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Is it worth fixing up my MacBook Pro 13" Mid 2009?
MacBook Pro 13" Unibody Mid 2009 2.53 GHz Core 2 Duo processor 250 GB Hard drive 2 GB RAM Running Mavericks version 10.9
My Macbook Pro 13" Mid 2009 has been causing me several problems lately, and I'm curious about whether it is worth spending the money to fix.
Current problems:
-Battery status is "Replace Now"
-It is really, really slow. I'm thinking this might be a RAM issue, but I am unsure. I don't know how to gauge this from the new Mavericks Activity Monitor design.
-Trackpad does not allow me to press to click, I can only tap to click (i.e. I cannot physically press the trackpad to click, I can only tap the surface)
-Occasionally (once every two weeks) will have kernel panics that will cause it to reboot. I do not know what causes these, no discernible pattern. When it reboots, the internal clock resets to January 1 2000.
Any and all advice would be helpful. I have not opened up my laptop ever, but feel competent enough to do so if it will be worth it.
I'm hesitant to try fixing it if people think it won't work, because costs are fairly high:
-$100 to buy two new 4GB RAM chips if I upgrade from 2 to 8 gig
-$112 for new battery
-$10-$20 for tools to open up my laptop/duster can
TOTAL: $250 just in upgrades
However, it's cheaper than a new Mac if you guys know that these things will resolve some of my problems! Thanks in advance for the help, please feel free to ask questions if you need more info
4 Comments
Sometimes one can find a replacement at reasonable cost on Craigslist, & sometimes it can be both an upgrade as well as a working replacement. But U & the seller must be willing to do a thorough check before you decide.
by
It’s worth upgrading I did my mid 2009 Pro to 8 ram 120 ssd works great and fast
by
I have a Apple MacBook Pro 17 or 15 inch that has this message and I can’t get past.. is it fixable? Choose start up disk no disk available.. then window you can’t change the startup disk
by
Yea, I suffered the same. Changed the SSD cable (50usd) that connects the motherboard to hardisk that created the kernel panic issue, changed by battery (150usd) Working fine now.
by
Add a comment
Chosen Solution
Your battery sounds like it has gone bad and has swollen causing trackpad issues. Also change out the hard drive cable as it is probably faulty.
MacBook Pro 13" Unibody Mid 2009 Battery Replacement
MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement
MacBook Pro 13" Unibody Mid 2009 Battery Image
Guide
Difficulty:
Easy
5 - 10 minutes
MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Image
Guide
Difficulty:
Easy
30 minutes
Score 6
2 Comments:
The trackpad issue has been there since the computer was less than a year old...would that still be the likely issue?
Thanks for the info!
by
I don't know. I can't open it and LOOK.
by
Add a comment
Sorry I'm late to the conversation. Upgrading is better than replacement.
I just purchased a battery ($63), 240GB SSD ($145), and USB external enclosure ($12) for less than $250 (crucial website for SSD and amazon for battery)
This is for my wife's mid 2009 13" MacBook pro. IMO, you will see more performance gain from an SSD than the 8GB of RAM. Don't get me wrong, 8 would help, but SSD would help more. I ordered wife's MacBook with 4GB of RAM, so going to 8 is not going to show as big of a difference for hers.
Check the model number of your hard drive. If it is a 5200 RPM drive, then I would recommend an SSD over RAM.
USB enclosure will make the old HDD useable for storage and backup.
If you have to do 1 item at a time because of funds, I completely understand. Definitely get that battery done first if it's swelling.
Think of it as this, do I put $250 into this laptop or spend $1200+ on a new one?
Good luck!
I will be replacing parts in about a week.
Score 1
Add a comment
I have the exact same macbook pro and I had many of the similar issues.. I recently spent $300 to upgrade it and I dont regret it. Added 8 Gigs or RAM (previously 4), 500GB ssd (previously 500 GB 5400 RPM HD), Replaced the battery..
The computer runs lightning fast now, boots in 20-22 seconds. everything is super fast..
Considering how expensive these laptops are, it'd be worth it to upgrade your existing computer rather than buying a new one.
Score 1
1 Comment:
I did almost identical upgrades. Did you have any issues with the fan making too much noise and never slowing down?
by
Add a comment
I am in pretty much the exact same situation. Having the same specs on this machine as OP, my battery suddenly reports being in the "Replace Now" condition, causing the trackpad issues. I plan to upgrade the HDD to a 120gb SSD, 8GB Ram and a new battery. These three fixes should add new life to the pro and the specs will be comparable to the new machines out there, bar the extra ports, thinner profile, processor and graphics card. Since this macbook pro is not going to be my primary machine, the processor and graphics are good enough, and the speed boost will make me fall in love with the pro all over again. Definitely worth considering the upgrade compared to buying a new pro.
1 Comment:
so as mentioned above, I took the plunge and fixed up my pro with an ssd and 8 gb of ram. The boot time went from being ~90s to now 15s. Definitely a significant improvement in usability as well.
by
Add a comment
Over the years I've upgraded several older Macs with SSDs, RAM and batteries. All have been totally worth the cost. So I had great expectations when I recently upgraded my wife's 2009 MacBook Pro (13"). I put in a new battery, 256GB SSD, and RAM to bring it up to 8GB.
Once done, the machine would not boot reliably. So I replaced the hard drive cable thinking I had damaged the delicate thing while replacing the drive. No improvement! The machine will boot reliably - albeit slowly - when the SSD is in an external enclosure. All I can figure is that the hard drive cable socket on the main logic board has been damaged.
So after spending about $250 on the machine, I think I owe my wife a new reliable Mac! She will be able to use the new SSD in an external enclosure with her new Mac, so that wasn't a waste of money.
So usually these upgrades of old machines work well, but sometimes you gamble and lose!
1 Comment:
Hello!
What INTERNAL SSD model do you recommend for a mid 2009 MacBook Pro (250gb) ?
Thank you
by
Add a comment
Add your answer
Michelle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 17,952
