Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20032 Questions View all
Question Closed
Can't start my MacBook, turns off when I release the power button
MacBook Pro early 2008
As the topic I can't start my MacBook. When I press and hold the power button i can hear the CD-ROM drive, fans, sleep mode indicator and my hard drive to start. But when I release the power button everything quits and I hear a quite beep sound from the side where the hard drive sits. The screen is black.
When I try to hold the power button longer (about 5 seconds) the sleep mode indicator start to flash fast and then the computer quits.
The problem started after I was working with logic pro and closed the screen for sleep mode. When I came back I couldn't start it. Lately my computer has been slow and my processor been almost working on maximum.
I have tried lots of things, resetting the SMC, safe mode (don't pass the release button), resetting PRAM, hold down ctrl + command + power, changing the RAM circuits with an old MacBook pro think 2006 model that works.
I thought it could be my harddrive so I tested it in the old MacBook and it worked (but it wanted me to resett to 10.6 or something).
My MacBook is running mountain lion.
Do someone know what the problem is and how to fix it.
Can you some how check what hardware is not working? It's a old computer and I don't want to put lots off money to fixit so I hope it's not the motherboard.
Thanks
Add a comment
1 Answer
Chosen Solution
Might be the HD cable... try to boot with an external case or from a target booted other mac.
If this answer is acceptable please remember to return and mark it.
Score 1
3 Comments:
Thanks for replying :)
I tried to start it from target booted macbook with a fire wire cable. But it didn't work. Could not find the hard drive and the MacBook who don't start still quits after I realese the power button :/
by
If it's no the drive that only leaves the cable / connector on the board.
by
From both the battery and the power cable to the board? Or do you mean the power to the hard drive?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 421
