Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
iPhone freezing, screen flickering
Hello,
I have an iPhone 4s in white it's 16GB model. So the screen is flickering and showing little black boxes.
the phone is also freezing on about 5-10 minutes of using so everytime I need to reset it with both buttons.
the problem is shown here : http://www.youtube.com/watch?v=fue9mv5Ps...
What to do? Its not in warranty anymore. I tried to replace screen, it's the same.
It has never fall on the floor or been in the water or anyrhing like that.
Thanks, and sorry for bad english.
Score 3
Add a comment
Chosen Solution
try turning the brightness down a little, worked for me!
Score 1
1 Comment:
that worked for me but what does that mean ? screen is bad or making a bad ground
by
Add a comment
Go to settings-general-about-diags&usage to see any relevant crash reports. Restore to the newest OS to see if the issue persists. If the phone still freezes, it is usually a hardware issue. You may have to replace components or even the logic board
Add a comment
Hi, my iPhone 4S is having similar problems but it flickers very badly. It's the worst on the camera or on snap chat anything that has anything to do with a camera. But no problem whilst using the front camera. Any suggestions on what it may be, or what is causing it, also my lock button ribbon cable was taken out because it was making my phone freeze and crash ever 5 minutes, also I have iOS7.2 if that helps. Thanks
2 Comments:
I m facing the same problem,plz kindly inform me if u get the solution..
by
iPhone 4 screen flashes in the bottom of the screen
by
Add a comment
Cleaning the cache should resolve the freezing problem. As to flicking, try to replace the screen protector instead. It seems it was dirty.
Add a comment
reboot it 2 times
than reset it
Add a comment
https://www.youtube.com/watch?v=VNBhlzyv...
This worked for me!
Add a comment
Hey I don't know if this will help but I heared if u go to settings and turn off auto brightness the. Turn it down leave it for 5 minuets and then turn auto brightness back on and then turn the brightness back up and it may work but it might not worth a try though
Add a comment
1: Turn Down Brightness
2:Wait 5 min. To 2 hr
IT WILL WORK
Add a comment
Add your answer
Greg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 14
All Time: 76,662
