Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
MacBook Pro Late 2011 won't power on
While connecting a LogiLink Solar Charger (http://logilink.com/showproduct/PA0055.h...) to my MacBook Pro via USB it went off immediately and shows no sign of life since.
The Magsafe light is neither green nor amber nor dim: it's off; the very same Magsafe unit however works flawlessly on another MacBook Pro, including the green/amber light.
When the battery indicator button is pressed, not a single led goes on, despite the battery was on 100% when the incident happened.
Needless to say, the MacBook does not power on. Simply put, it does totally nothing.
Could a fuse be blown or should I assume that the whole thing is toast? Any help is appreciated.
Score 2
Add a comment
1 Answer
Chosen Solution
In case your interested, the case is now solved.
I disconnected the battery and then connected the Magsafe unit: the MBP powered on and started the boot sequence. Disconnected the Magsafe, re-connected the battery and then re-connected the Magsafe: the MBP powered on again.
The battery indicator shows that the battery is completely discharged, but now it is charging again. I guess the incident did nothing good to it, but at least the MBP is up and running.
Score 2
1 Comment:
Exact same thing happened to me and this fix worked. I did not need to boot it off of the Magsafe. Just disconnecting the battery connector, letting it sit for a few seconds, and then snapping it back on was all that was needed.
by
Add a comment
Add your answer
Peter N will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 619
