Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3298 Questions View all
Home Button Clicks but doesn't work- ripped rubber
I replaced my screen by following the guide on iFixit. Everything worked perfectly except now my home button doesn't work. It clicks normally, but has no response on the phone. When I was replacing the screen, the rubber edge of one side of the button ripped off. The guide said explicitly to make sure this doesn't happen, but it was a really small part of the rubber. Is that little bit of rubber that tore off causing this problem?
Should I order a new button and replace my current one?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
First go in and check the slot where the button locks into place on the inside of the phone.
Use the ifix guide for that model of phone to walk you to the home button replacement if you need to order a replacement flex cable there only a buck or two on ebay
Score 1
Add a comment
I agree with the first answer.
I have found the home button to be notoriously unreliable on all iPhones and iPads
Cheers Paul
Add a comment
I agree with Gary, also to check the homebutton, you can disassemble the phone and bridge the homebutton receptor to see if it responds. This means having the phone on and disassembled at the same time.
On this image:
http://d3nevzfk7ii3be.cloudfront.net/igi...
Notice the two copperish things centered below the battery? Bridge those with something conductive, a screwdriver usually works and see if the phone responds. If it does replace the flex cable.
Add a comment
Add your answer
bhkonig will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 1,996
