cycle lights blink washer will not run
washer will not run . no codes, cycle light will blink once when start is pushed
Unplug it for 5 minutes to allow it to reset then plug it back in and see if it gives you any codes.
the door lock light didn't come on. when I unplugged the electric and plugged it back in the door light came on. it ran thru a couple minutes then shut off when the door light went out. can you help me? thank you.
fred
when i put a load in it starts and then stops and the light start blinking and i have to move the cloths around in the drum - or take some cloths out - but that only works sometimes.
Washer stopped with twelve minutes left on the timer clothes are dry enough to take out.the washer will not restart. I unpluged the machine for five minutes and when plugged back in no code appeared. When it was plugged back in a real low hum could be heard but still will not do anything
After turning power on I push the start button and hear a humming noise. Please help
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 2,101
