Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1417 Questions View all
CAN'T Replace Hard Drive DOES NOT READ it! HELP!
Bought by IFIXIT suggestion
1TB 5400 RPM Toshiba SATA Hard Drive (new)
I read it was compatible with my macbook so I went
for it - when I try to change it - twice it didn't read it
at all.
My brother had a similar problem with its macbook pro
when it came to hard drive of 1TB.
Now I wonder is there any chance I can still use this hard drive internal or should I give up get a case and use it as external!?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Your have given very generic information about your machine and HD. Your machine has (can only use) Serial ATA (1.5 Gb/s). If the new drive is SATA II/III (3 to 6GB/s) it wont work. SOME drives can be manually set to SATA I - some can not.
Some external cases can automagically match USB speed - so that may work.
If this Answer is helpful please remember to return and mark it Accepted.
Comments:
Hi @machead3,tnx for your answer.
So here my HD Serial ATA from 160GB or 250GB to 5400 giri/min
(its italian I don't how to translate it to you in english).
About my New HD I think its a SATA2 (TOSHIBA MQ01ABD100)
how do I understand if I can manually set it to SATA1? and if I
can how do I do it?
by
Generally SATA II can drop back one version without problems - the manufacturers site should have information/instructions about this. Contact their support department.
by
Add a comment
Add your answer
cirillica will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 82
