13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Question Closed
My SuperDrive no longer accepts media. Options short of replacement?
My 2.0 GHz Aluminum Macbook's SATA SuperDrive (HLDT GS21N) no longer accepts media - recorded CD/DVD or blank CD/DVD. I can hear the spin-up sound when the machine boots, but it feels as if something's blocking the disks about 2cm from the right side as I try to insert them. The drive makes no attempt to grab the disk, and I can't hear any mechanical sounds from the drive, other than the spin-up at boot.
I've pulled the drive and opened it up per the iFixit manuals (A1278 Optical Drive Replacement; Optical Drive Disc Removal), and I can't find anything obviously wrong. There's no foreign objects in the drive. I'm not sure what to check to be sure that the eject mechanism works. I didn't have any kind of adapter to convert the drive for use with external SATA enclosure, so I couldn't test it to see if it was a power issue.
All software on the internal drive reports the drive as present, presumably functional: System Profiler, Disk Utility, Toast 11. The OS is 10.6.8.
Are there any repair options left, or should I just replace it? Thanks!
MacBook Unibody Model A1278 Optical Drive Image
Guide
MacBook Unibody Model A1278 Optical Drive Replacement
Difficulty:
Moderate
30 minutes - 1 hour
Optical Drive Image
Guide
Optical Drive Disc Removal Technique, or Foreign Object Removal
Difficulty:
Easy
1 - 10 minutes
Add a comment
1 Answer
Chosen Solution
I'd replace it - repairing Optical Disk Drives is not a DIY project. It would require lots of specail tools and experience.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 8
All Time: 266
