Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
The half right screen is grey, alfter a boton replacement.
Hello, I just replace my lock botton and when I turn on the phone, the The half right screen is grey. The phone works 100%, but the half right screen is grey.
How I can fix it?
Thanks
Regards
Score -1
Add a comment
1 Answer
Chosen Solution
Im guessing if you replaced the prox flex cable, you did not remove the screen. In which case, you have to heavily bend and shift those display cables around to get into the assembly and remove screws etc. You probably damaged the LCD connector. Which is why you should always remove the screen to replace a power button / Proximity flex cable.
Try a new screen and it will resolve the display issues.
Hope this helps!
Add a comment
Add your answer
Paulo Blanco will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,258
