Repair guides and support for camcorders and other video cameras.
406 Questions View all
The moisture warning is on permenantly.
The moisture warning on my Panasonic CamcorderNV-DS65EN is always on, even when the camera has been kept in a warm, dry environment for 24 hours. I suspect that the moisture sensor has failed, but have no idea where in the camera it is fitted and what disassembly is necessary to reach it. Replacing it would be no problem if only I could find it!
Score -1
Add a comment
1 Answer
Most Helpful Answer
Electronic moisture sensors have to be exposed to the air somehow, the ICs often have a small cut in them with a felt window that looks similar to what you see on a small microphone.
Score 1
Add a comment
Add your answer
Graham S Dawson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 590
