Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
How do I fix my stuck lock button?
I've taken a look at the lock button and the actual mechanism seems to be fine. I can click it with my finger perfectly but when I try to click the mechanism using the actual button it just doesn't do anything. If I buy a new button is this guaranteed to fix it? If so should I get the metal button or the actual mechanism or both? Thank you
Score -1
Add a comment
1 Answer
Chosen Solution
If you dismassembled your iPhone yourself, the warantee may not work. Even if you can manually click on the sensor cable, it can and is certainly used and Will no longer work with the button. You Will find a new power sensor cable @ ifixit store for $15 and easily replace it by following their step-by-step replacement guide. I had the same problem :)
Hope I have helped you !
Vincent
[linked product missing or disabled: IF182-015]
Add a comment
Add your answer
mikey lloyd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,354
