Repair guides and disassembly information for Apple's Macintosh personal computers.
I accidentally deleted mac partition while creating a dual-boot
i am having a mid 2011 macbook pro.while i was creating a dual-boot on mac for windows,thought of making changes to the partition but,i end up deleting the whole mac partition.now i am using windows 8 on this macbook and i want to re-install mac os on it..i went through lot of forums on many websites all i could find is installing mac on windows using virtual machine. BUT I WANT A CLEAN INSTALLATION OF MAC OSX..i even have a installation disc of osx through which i tried to install,it asks me to press 'C' on startup when i do so it got hanged on apple logo screen...please help me to find a solution
Score 1
Add a comment
Chosen Solution
holding down the option key, as mentioned above, will get you to the 'disk selection screen'. this will show a list of all bootable sources connected to the machine. (holding down the 'C' key will do the same thing, but instead of bringing up a list, it boots directly to the optical drive)
If it is locking up on the apple logo after selecting the boot source, it is not to do with your current hard drive setup, it will be to do with either the install disk you have (it could be corrupt, damaged or from an incompatible range) or you optical drive may be faulty. Can you confirm if you machine was made in Early 2011 or Late 2011? you can identify this by the function symbols over the F3 adn F4 keys on the keyboard. (The early range has 3 boxes within a box, whereas the late just has 3 boxes on a larger scale) the late 2011 range has a network recovery option with lion, which is an easy route that i can explain if you need. otherwise, get a USB installer, or access the machine through target disk mode on another machine (if you have another intel mac around to work with)
Score 1
Add a comment
Most Helpful Answer
Hold down the option key - choose the installation disk. You will have to reformat the entire disk in GUID partition table Format (losing all current data) before you can install.
Read this article from Apple.
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
Add a comment
Add your answer
vikram will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 3,019
