Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
battery change on 3g
I change the battery on the 3g but cant speak or hear unless its on speaker phone
Score 1
Add a comment
Most Helpful Answer
I am having the same prob did you fix yours?
Score 1
1 Comment:
if you start your own question or browse through the solutions you are more likely to get an answer.this question is from april, i know recently there have been lots of similar problems solved . check connector no 3
by
Add a comment
You probably left something unconnected in the repair, go back through the guide and make sure nothing is disconnected.
Add a comment
Add your answer
safetmtv will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 802
