Repair guides and disassembly information for PC laptops of all shapes, sizes, and colors.
18921 Questions View all
Can I plug in my laptop without the battery?
My laptop battery needs to be replaced but I can't buy one right now. Can I just remove the battery and plug in my laptop? If yes, will it have negative effect on my laptop performance or hard drive? Please advise. Thank you.
Score -1
1 Comment
batterynew dsad, you wouldn't be trying to spam on here, would you? I noticed that your other question has the same links, even so you are inquiring about a different computer and different situation.........
by
Add a comment
Chosen Solution
I no longer buy replacement batteries, but just run the computer with the battery removed. For trips I use an inexpensive DC to AC converter (Wal-Mart has them for about $25) and plug it into my cars DC outlet to operate at free wi-fi stations. Good luck.
Here is a link to one that OWC sells. Others are available.
http://eshop.macsales.com/item/Virtual%2...
Score 2
1 Comment:
Just don't pull the cord out by mistake without a batt ;-}
by
Add a comment
I suppose there's no harm in doing so. I've had laptops where the battery had failed completely (dead, therefore not detected anymore) and they still work running off the AC adaptor only. If I unplug off the main AC, the laptops power off and die immediately,
Score 1
Add a comment
Add your answer
batterynew dsad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,252
