Automobiles by General Motor's Pontiac brand. Pontiac was founded in 1926 and became defunct in 2010.
336 Questions View all
Why does the engine crank but not start in my Pontiac Sunfire 2004?
I have a Pontiac Sunfire 2004 2.2 engine. The motor cranks over but will not start had a new gas pump put in the tank new fuse under the hood put in for the fule pump,inline filter put in, ran good for a good 3 days , now it turn over but wont start.
thank u Gary
Score -1
3 Comments
Do you have a spark?
by
yes have good spark in all plugs
by
broken fuel pump??
by
Add a comment
Chosen Solution
Could be injector pressure regulator, injectors, controller board. Trouble codes from the engine may point to the trouble . Pull the oil dipstick and look for moisture (sign of a blown head-gasket).
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
It’s in the wiring for the fuel pump! Under the hood pull fuel pump relay and plug back in! Should start!
1 Comment:
There are so many possible things wrong. Pulling and putting back a relay may work in very limited cases, but if so this shows the relay to be faulty and sticking internally so it should be replaced. Could also be actual fuel pump failure, fuel pressure regulator, injectors, or a number of other things. Engine codes would narrow it down, as would other tests. You just don't know until you start checking.
by
Add a comment
Add your answer
Gary buchinger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 1,668
