Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Question Closed
No sound from the earpiece but speakerphone works
Hi I just replaced my rear panel, I had to totally dissembled the whole device. After putting everything back togher, I cannot hear anything from the earpiece during a call, the speakerphone works.
I checked every connection and also double checked cable #3.
I also plugged and removed headphones into the headphone jack numerous times (searched google and this could be a remedy)
I also lost a screw but it doesnt look like it makes any contact with anything.
Third red circle I lost the screw thats next to the orange circle.
Update
Anyone?
Add a comment
i think you mean the bottom row on that picture - right?
the screw should not be the problem.
does the proximity sensor work??
most problems are related to cable/connector 3 - but it's also possible that the earpice is faulty.
Add a comment
Hello i was having the same issue, and the solution is little tricky
but works for me ....
when you connect the number 3, pull the connector cable a little backward
just a little (like 0.8 mm or 0.5 mm) and flip down the white plastic tab
Repeat this until you heard something
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 3,356
