The iMac G5, powered by the PowerPC G5 processor, was originally released in 2004.
586 Questions View all
Need pinout for iMac's iR sensor (iSight)
RE: iMac G5 (iSight)
IR part: 820-1884-A
Need pinouts for J1 and J2 (I presume alternate solder points).
As best I can tell, the iR sensor from the iMac is USB. A while back (before I had one with a built in camera or iR, I saw a USB pinout.)
Anyway, I now have a dead iMac with iSight and iR sensor. I'm looking for the iR sensors pinout so I can convert it to a standard USB cable and jam it into a PowerMac G5 tower (which never had an iR sensor.)
Any help would be appreciated.
Score 1
Add a comment
1 Answer
Chosen Solution
Not sure if this is what you want or not but here is one persons answer. Good luck Ralph
http://www.applefritter.com/node/23056
Score 3
Comments:
Answer near the bottom of the page. Ralph
by
+ research
by
Do you think this board is still supported in modern (10.8+) OSes? Should I buy this, or the more expensive MacBook Pro IR board?
by
Add a comment
Add your answer
ct2193 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 2,691
