Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
No service or very weak signal
Hello.
I just replaced the home button on my iPhone 4. After i reassembled my iPhone I didn't have any service. When i go to the window in my room I get a very weak signal from a carrier but unfortunately not the right one. Can you help? I really miss my opportunity for texting.
Score -1
Add a comment
1 Answer
Chosen Solution
Make sure you did not ruin the board when working on your device. Prying connectors not carefully enough may damage the connector or very small parts around it.
if you are certain that the logic board is ok, then try reconnecting the lower antenna cable, the black coax cable with a metal connector. if still not working, check the screw on the right end of the speaker. make sure there is a metal washer beneath the screw and the screw is properly tightened.
1 Comment:
It works perfectly now. I reassembled it again again and then it worked. :-)
by
Add a comment
Add your answer
Mathias will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 292
