Water Damage / Charges / Makes Sounds / NO TURN ON
Hello!
Thank you so much for reading my question. I need help on an iphone 5 verizon 16gb. I opened it up and swapped out the battery and the LCD to a working unit and both battery and LCD are working. But when swapping them back in the iphone 5 it just charges, vibrates, and makes noises. THE SCREEN does NOT turn on. I even got a new battery and LCD to make sure. I notice on the water damaged iphone 5, the "Interconnect Cables Mother Logic Board Flex Cables" were broken, so i had to replace those. I also noticed that on the "logic board with Back Facing Camera", where the LCD connects to the board. the connectors on the board do not clean silver color, more of a blacked out. on one guide it states to: "When reassembling your phone, The LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best was to power cycle your phone is to disconnect and reconnect the battery." Which i have done over and over again! Please help me. Any advice, tips, suggestions would be greatly appreciated!
